Re: Farmall C Pistons Stuck Rods Stuck, too
Posted by PurdueAg on April 30, 2005 at 07:10:29 from (198.109.220.6):
In Reply to: Re: Farmall C Pistons Stuck Rods Stuck, too posted by El Toro on April 30, 2005 at 06:59:45:
third party image
Thanks for the info. If I get the pulley off, can I
drop the crankshaft straight down, or will I still
have to be able to move ot back and forth to
shimmey if out of there. The darned rods are
jammed in place on the crank. When I worked
on the H, the crank was stuck / positioned in
such a way that I could push the rods away
from the crank.
The outer center area of the pulley (where the
"key hole" is is broken off. I can't see where
the bolt is that attaches the pulley to the
crankshaft.
I'll bet that thing is going to be a b****. The
tractor is in pretty bad shape, and has set out
for years.
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
