Re: Farmall C Pistons Stuck Rods Stuck, too
Posted by El Toro on April 30, 2005 at 07:37:50 from (64.12.117.13):
In Reply to: Re: Farmall C Pistons Stuck Rods Stuck, too posted by PurdueAg on April 30, 2005 at 07:10:29:
Someone may have removed the damper bolt, look to see if any threads are in the crankshaft, I'm sure there should be. You do not want to pull
on the outer edges of the pulley, this may break
your pulley where the metal is thin. Squirt plenty of that tranny juice on both sides of those pistons since you have the engine pulled.
Using that 2X2 oak tap on those pistons to get them moving a little. Rust probably has them seized from being left in the weather so it's going to take awhile. Hal
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
