Re: weak hydraulics
Posted by Nat on April 30, 2005 at 13:18:23 from (64.80.110.40):
In Reply to: weak hydraulics posted by David A Hodson on April 30, 2005 at 10:17:18:
Making it 2-way won't help, unless you're running the reservoir out of fluid.
Is the valve on the tractor set up for 1-way? On top of each valve is a thing that you turn with a wrench to select 1-way or 2-way. On a 400, you have to practically disassemble the tractor to get to them, so it may be easier to convert it to 2-way.
Post a Followup
