Re: weak hydraulics
Posted by DWV on April 30, 2005 at 20:02:30 from (205.188.117.138):
In Reply to: weak hydraulics posted by David A Hodson on April 30, 2005 at 10:17:18:
Which hydraulic port are you hooked to? If the valve is set to single acting and using ports on
right or left of tractor the line to cylinder is suposed to connect to port to rear.If you happen to have the larger gas tank the outlet lines on
sides will be vertical.I think you hook to top outlet for single.Since you have fast hitch im guessing the cylinder line is not being used on the rear outlet lines bolted to battery box.Also guessing you have a 3 valve set up in giving this info.
Post a Followup
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
