Re: Farmall 706 Carb. advice
Posted by ZenBasser on May 18, 2005 at 19:08:58 from (67.41.244.107):
In Reply to: Re: Farmall 706 Carb. advice posted by Aces on December 08, 2004 at 05:41:03:
Can I follow along this thread? I've got a 706 that sat for 1 -3 years. I've drained the gas --- it was total varnish. Emptied and cleaned the sediment bowl. Removed, flushed and cleaned the fuel line. Removed the carb, had it soaked, and new gasket, float, and valve. (But not new solenoid)
I can turn the 706 over -- and with small amounts of gas manually poured in the carb -- it will run -- but it's dying as soon as that gas is gone.
I'm probably forgetting something obvious - but is maybe the solenoid got the gas shut off?
(yes, I've opened the gas at the bowl -- and gas flows well through the line up to the carb.
What am I forgetting? What next?
Thanks
Post a Followup
