Altenator question Farmall H HELP
Posted by MagMan on May 21, 2005 at 12:03:49 from (152.163.101.13):
Hi guys I have a farmall H with what I believe is a GM altenator under the hood. it fits with no cut out or having to unhook the hood. it has a wire for the return charging and then a plug in with two wires.
One of the pigtail wires goes to the charge stud and the other goes to a on off switch then the charge termenal wire goes to the battery directly. OK now this is the problem. If I dont turn the push pull switch on Re: the wire that goes to the plug in on the alt it does not make any difference still charges. But if I leave the wire hooked to the battery it shows a small discharge and runs the bat dead. That wire goes from the bat directly to the stud on the alt.Any Help would be apreatiated.iT DOES CHARGE OK WHEN RUNNING THOUGH
JON
Post a Followup
