560 Trans ??????
Posted by 560puller on May 29, 2005 at 15:28:05 from (199.174.0.69):
There are two covers on the bottom of the trans housing that bolt on,my question is can the gear and shaft that drive the hydraulic pump be taken out through these holes or do I have too split the tractor.If it has to be split does it split between the engine and trans or trans too rearend?I built this tractor as a puller and it has a rattle on under the T/A which is new I suspect the bearing on the hydraulic pump drive shaft but who knows? Thanks for the help. 560puller
Post a Followup
