Re: 560 Trans ??????
Posted by Aces on May 29, 2005 at 17:19:38 from (4.164.162.93):
In Reply to: 560 Trans ?????? posted by 560puller on May 29, 2005 at 15:28:05:
560puller. You can't do much the bottom plates. If you need to change the PTO and hydraulics pump drive you will have to split the tractor at the clutch housing right behind the engine.
Post a Followup
