Re: Super C axel seal HELP!
Posted by Wayne Swenson on June 01, 2005 at 20:47:53 from (66.191.70.4):
In Reply to: Super C axel seal HELP! posted by Andrew Z on June 01, 2005 at 19:29:01:
Put a large size nut against the end of the axle you are trying to remove and then pry against it using the opposite axle as a fulcrum point.
Axles are a tight fit on the splines so will not be easy to remove.
Post a Followup
