Re: 1948 C Restoration
Posted by El Toro on June 04, 2005 at 08:38:24 from (64.12.117.13):
In Reply to: 1948 C Restoration posted by Pharmall on June 04, 2005 at 07:08:57:
The A, B and C C113 blocks would accept the 3.125"
sleeve and piston kit without any machining to the block. Those wet sleeves can be removed with
a piece of oak or maple wood. They're not pressed
in. Just tap them lightly so you don't damage the block. Be sure to clean the block area where those sleeve seals (doughnuts) are installed. You don't want any water leakage
on those sleeves.
That damper pulley probably has a groove worn into the metal from the old seal. You can install
a speedy-sleeve to cover that and are available
from NAPA or your local auto store that sells Chicago Rawhide seals. That would stop your oil leakage.
I have a sketch of a sleeve puller, if you want a copy send me an email. Your local machine shop can make one for you. Hal
Post a Followup
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
