Re: F-12/14 Hysler overdrive ?
Posted by ET on June 06, 2005 at 09:20:53 from (134.179.250.43):
In Reply to: F-12/14 Hysler overdrive ? posted by Bobcat on June 05, 2005 at 17:43:28:
I have a F12 with a hysler overdrive in it. I did not install it but have heard some stories from the oldtimers looking it over. I believe the transmission input shaft with the bevel gear on it and the bearing quill it mounts in are removed and the overdrive unit bolts to the front of the transmission in place of the bearing quill. The overdrive has its own bevel gear. There is only one of the flex couplers left in the drive shaft in front of the overdrive. The bevel gear is diffrent between the F12 and F14, it may have hielical cut teeth on the F14 unit.
Post a Followup
