Re: Super A running weak
Posted by El Toro on June 12, 2005 at 08:39:14 from (64.12.117.13):
In Reply to: Super A running weak posted by SteveSa on June 11, 2005 at 22:00:54:
Loosen the tube nut at the carburetor to see if you have good flow to the carb. and not just a drip. If flow is poor you need to clean the sediment bowl, strainer and gas tank too if you see a lot of crud in there like rust and dirt.
If flow is good at carb. your carburetor needs to be cleaned and soaked in cleaner. It may have a varnish like coating inside the carb. from old gasoline. Use a fuel stabilizer if the tractor sits unused for long periods of time. Hal
Post a Followup
