Super A running weak
Posted by SteveSa on June 11, 2005 at 22:00:54 from (69.26.12.107):
Hello All
I have a 51 SA that I am having a time gettin to run well. I have checked comp.-3 holes right around 100 with one about 7-10 lower. Put in points, plugs, rotor, dist. cap. Starts and idles well but does not accelerate much-pulled the governor rod tonight and got more power but still seems weak to me. Just looking for suggestions from the good ol Farmall Hands on this forum. Carb next? Could oil bath air cleaner raise heck with the engines top end? Any ideas? Thanks for any input-Steve
Post a Followup
