Re: Super A running weak
Posted by SteveSa on June 12, 2005 at 12:54:53 from (69.26.12.107):
In Reply to: Super A running weak posted by SteveSa on June 11, 2005 at 22:00:54:
To El Toro, Nat, and Jeff-thank you for the input.
I will try everything suggested-just wasn't sure which way to turn next.
Nat-by weak I mean the tractor runs pretty smoothly up to about 1/3 of its potential(with the throttle wide open-on the carb) and has a very soft "whoofing" type sound. Then just doesn't have any power coming up a small hill or with a little load and dies. Thanks Steve
Post a Followup
