Clutch Locked up - Help
Posted by Farmall Frank on June 13, 2005 at 12:50:12 from (65.30.114.71):
Split my 400D, replaced the clutch disk, then joined the tractor, but now the clutch is apparently locked to the flywheel/pressure plate. With the unit running, trying to shift out of neutral causes nasty grinding noises. I can shift with the engine off. I adjusted the clutch according to written instructions, still to no avail. I locked he pressure plate open (with 3 bolts that draws the plate up), and still it is connected to the flywheel. I even put the tractor in gear, shoved the clutch as far as possible, tried to start it, and of course, the tractor moved forward. I was hoping this would free it, but the tractor tried to climb a couple cinder blocks. Nothing I can do frees the clutch disk. I removed the inspection plate and observed the operation of the three clutch release levers against the throwout bearing, and they appear to be working. Now the confession. When joining the tractor (using threaded rod), I got the alignment off center and cocked to one side, and applied a lot of force with the rod to the point of having the ring gear scratch the inside of the bell housing. Could see that the clutch shaft was cocked inside the pressure plate. Noticed the problem and tried again, getting it joined. Could I have screwed up the clutch disk with the clutch shaft when it went in cocked? What did I do wrong? The power take-off spins when the handle is engaged, if that means anything. Dang, just finished painting it, putting in all new wiring, TA, along with a bunch of other stuff, now I suppose it must be split again. How depressing!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
