Re: Clutch Locked up - Help
Posted by captaink on June 13, 2005 at 13:12:19 from (66.115.214.56):
In Reply to: Clutch Locked up - Help posted by Farmall Frank on June 13, 2005 at 12:50:12:
I have a few thoughts for you to consider. My first question is the clutch disk in correctly? On some applications if the clutch disk is put in backwards it will not release because the hub is interfering with the flywheel. By forcing it together you may have damaged the clutch disk by bending the hub area forward causing the clutch to bind up. The reason your PTO turns is that it is driven by the splined hub in the pressure plate and the hollow tube that drives the hydraulics and the PTO. The clutch shaft will interfere with the clutch disk before the PTO shaft in the pressure plate because of the additional length for the pilot bearing which brings me to the other thought. The pilot bearing may be damaged to the point that it will not rotate freely. Since the outside of the bearing rotates with the engine, a bad bearing will not let the shaft in the middle stop allowing the transmission gears to stop. Any of these will take a split to correct.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
