Re: How to remove steering shaft from box on SA
Posted by Dixieland on June 15, 2005 at 18:46:52 from (207.119.210.195):
In Reply to: How to remove steering shaft from box on SA posted by scott#2 on June 15, 2005 at 15:57:01:
You will have to jack up the tractor's front end to remove the shaft and you will need to very carefull. You cannot jack up the steering section(axle), you will have to jack up the front of the torque tube or remove the oil pan and place a solid support beam across the bottom of the engine block. Be sure to scotch off the rear wheels.
Post a Followup
