Re: McCormick Deering WD-9 Engine Problem Question
Posted by Geoff NY on June 18, 2005 at 14:45:11 from (24.185.225.190):
In Reply to: McCormick Deering WD-9 Engine Problem Questions posted by billcrews on June 18, 2005 at 06:17:50:
The compression release lever that you mentioned.... sounds like it needs to be adjusted. It not only opens valves in the head to lower compression, it also opens butterfly valves in the intake manifold (allowing gas in), and opens the float valve, and allows spark to go to the plugs. So, as you can see if this isn"t all happening, it won"t run. Amazing that it starts on diesel, none of mine will cold. Good luck and have fun. Geoff
Post a Followup
