Re: Drawbar for a 140 hi-clear
Posted by Hugh MacKay on June 23, 2005 at 02:20:42 from (216.208.58.179):
In Reply to: Drawbar for a 140 hi-clear posted by Swampcat on June 22, 2005 at 20:03:09:
Unless you can find one of the hitch plates Jim speaks of, best idea is make one. They are tapered and wide enough at drawbar crossbar to bolt on using two bolts. Make it so you use a hole on crossbar as well as second hole from the first. (about 5" to 6" apart, much easier to keep tight than two consecutive holes) Also drill holes to match holes in crossbar and use bolts to match. Make this hitch plate long enough so drawbar pin hole at end will be 14" from end of PTO shaft. The plate should be 5/8" thick, 7" wide at point where it bolts to cross bar tapering to about 3" at hitching end. I will suggest making plate from 3/4" thick plate as you will be using mild steel, IH probably use forged steel.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
