Re: Farmall M Clutch Pressure Plate
Posted by JohnG(TX) on June 28, 2005 at 13:04:51 from (216.136.20.34):
In Reply to: Re: Farmall M Clutch Pressure Plate posted by Haas on June 28, 2005 at 12:49:53:
I have the main drive coupling out, along with the bolts for the throw out bearing support bracket and the bolts that hold the disengagement fork onto the clutch release shaft. I have not pulled the clutch release shaft out, but that should just entail removing the two washers and yanking the shaft out the side. I was able to get everything loose up in there and I can rotate the release fork up and out of the way.
I am guessing that the pressure plate and clutch disk must be angled downward to allow the clutch shaft to be pulled out past the pinion drive. I have the pinion bearing cage loose, but it does not have enough room to slide forward far enough to clear the clutch shaft. So, I am back to trying to get the pressure plate loose.
Post a Followup
