Re: Farmall M
Posted by Janicholson on June 29, 2005 at 15:11:17 from (66.173.50.48):
In Reply to: Re: Farmall M posted by Wayne Swenson on June 29, 2005 at 12:16:19:
The starter uses an Inertia powered engagement mechanism. The starter motor spins with a fierce increase in speed. The drive pinion does not spin as rapidly, and as a result it spirals out against the end of its travel and is engaged with the ring gear. I suspect either stickie lube on the spiral, or no lube. Clean with a spray electrical cleaner, and usw some 10-30 on the spiral of the starter drive. A weak battery/bad or small cables can prevent enough startup inertia. It will go.
Jim Nicholson
Post a Followup
