Re: WD-9 Fuel Issue
Posted by P Backus on July 05, 2005 at 08:26:05 from (69.128.32.13):
In Reply to: WD-9 Fuel Issue posted by 67ssimpala on July 04, 2005 at 20:19:50:
Does it have puffs of white smoke coming out of the exhaust when idling? If so, I would suspect that number one has low compression. Then it won't completely burn the fuel at idle, but the additional heat and engine speed you have when under a load will burn the fuel better. You can do a compression check through the spark plug hole. Another way to check quickly is to crank the engine over with the throttle in the off position and the engine in the diesel setting (not the normal start on gas setting). Listen as it cranks. If it speeds up in one spot, then you have a compression issue. If you suspect that, you can put no.1 on TDC and put compressed air through the spark plug hole and listen for where the air is escaping. Exhaust pipe?-exhaust valve is leaking. You get the idea. Paul
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
