International Diesel running like a dog... :(
Posted by Derek Broerse on July 06, 2005 at 20:19:57 from (206.186.115.59):
My B275 (BD144 diesel four popper) pulled nice and strong when I got it about three months ago.
I took the fuel tank off to rebuild my steering system (and to clean it out etc too) and ever since it just doesn't run right.
The fuel is fresh and clean, filter is new, fuel pump is a-ok and freshly cleaned, lines were blown out, glass bowl cleaned, etc. I'll also mention that the air intake is freshly cleaned and re-oiled as well.
Tractor is very slow to rev up, even in neutrel. At full throttle it has a bit of a miss to it. Feels like it is only running on three cylinders.
Sounds like an air issue, doesn't it? Yet the plastic return tubes are bubble-free, and I can crack each injector line in turn and get pressurized fuel spray with an accompanying reduction in engine speed.
This is my first diesel, so I am learning alot as I go. Honestly, it has been a royal PITA but again its all new to me.
Any advice? I still have to split the tractor for the clutch fork, so I will probably have to repeat the whole process again but if it is something simple.....?
Thx!
Post a Followup
