Re: small venturi in 460 carb
Posted by rebuilder on July 13, 2005 at 05:17:39 from (66.228.102.104):
In Reply to: small venturi in 460 carb posted by Tim Shaw on July 12, 2005 at 19:35:26:
Tim:
You are right, someone has replaced the venturi. The "23" venturi are for Super H's and rarely I've found them in 300/350"s which are normally "25"'s The 460's I rebuilt almost always have the double wall venturi. This can be replaced with "27" by the book. The "30" which you remarked on is not found till you get to the C-291/C-301 engines normally
Post a Followup
