Re: wheel weights vs fluid in H rear wheels
Posted by old on July 31, 2005 at 07:25:58 from (207.69.137.135):
In Reply to: Re: wheel weights vs fluid in H rear wheels posted by colekicker on July 31, 2005 at 00:44:30:
Well as I said pullers don't use fluid because its not east to change weight with fluid. but as far as real tracktion fluid does a lot more the wheel weights. The fluid put most if not all its weight right on the point of the ground where the tire is doing its work and wheel weights put it all over the rear end etc. I've done both and to really get the rubber to the ground fluid is the way to go. For pulling on the track wheel weights are the way to go.
Post a Followup
