Re: wheel weights vs fluid in H rear wheels
Posted by colekicker on July 31, 2005 at 09:28:32 from (65.30.137.231):
In Reply to: Re: wheel weights vs fluid in H rear wheels posted by old on July 31, 2005 at 07:25:58:
Ok, so if we have weight all over the rearend, where does it get displaced? Not in the air. Mass is mass. When you run the tractor on a set of scales, just back the rear 2 tires on. See if you have the same amount of weight displaced about the foot print of both tires with air and with water. Its still the same amount of surface contact, but can still be the same amount of weight.
Post a Followup
