Re: questions on my '41H
Posted by CNKS on July 31, 2005 at 19:45:37 from (204.249.178.138):
In Reply to: questions on my '41H posted by awutay on July 31, 2005 at 19:29:55:
1. You can try the nut, but you may also need new packing, available from Case-IH. I have had problems stopping mine from leaking, I seem to be the only one with this problem, packing should solve it. To tighten the nut, you need a 7/8 inch stubby wrench. If combination, use the open end. It is a tight fit but can be manipulated to work. 2. Blue smoke is oil, I don't have an answer for the puffs, though. 3. Your system is not pressurized, not on a 41 anyway, unless you have a replacement pressure radiator. The gasket is really not that important. If you wish you should be able to find a new cap -- it must be the non-pressurized one, the pressure cap will not fit your radiator. You can tell the difference between pressurized and non-pressurized radiators, by looking at the radiator neck. If the cap fits on the outside of the neck it is pressurized, if the lip the cap fits in is on the inside of the neck, it is not pressurized. You don't need to seal a non-pressurized radiator. If Case-IH doesn't have the cap, OEM Tractor Parts and others will. Your cold engine is the rule and not the exception, they warm up very slowly.
Post a Followup
