Re: Farmall A - Brakes bad
Posted by Haas on August 01, 2005 at 09:11:21 from (12.65.30.40):
In Reply to: Re: Farmall A - Brakes bad posted by Tom Stork on August 01, 2005 at 07:27:17:
Yes, the shaft is just splined into the differential and slides right out when you pull the final drive off. Since there is no shaft in the hole, seals on transmission/differential housing are easy to replace. Brake drum must be pulled off the shaft to replace the seals on the final drive. As I recall (please doublecheck the diagram) you remove the cover with 4 bolts on the outside of the final drive and after the brake drum is pulled off the shaft(remove set screw that retains the drum), the shaft comes out the back side through the hole. Don't try to drive the shaft out of the brake drum, use a puller, as there is a key (woodruff half moon I think) that well catch on the seal and bearing race if you try to just drive it out. My experience, the brake drums come off easily.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
