Re: Farmall A - Brakes bad
Posted by Tom Stork on August 01, 2005 at 07:27:17 from (207.170.38.162):
In Reply to: Re: Farmall A - Brakes bad posted by Haas on July 29, 2005 at 18:19:20:
I've come up with a diagram and it appears that the entire diff. shaft comes out with the final drive. Is that true?
Thanks for your help.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
