Re: Farmall H carb flooding
Posted by old on August 04, 2005 at 09:42:32 from (207.69.137.207):
In Reply to: Farmall H carb flooding posted by greg wilson on August 04, 2005 at 08:55:03:
Well you said you reset the float up, well if you did that it means you set it so it would not shut off as fast. You need to set it per spec. or a litte lower. Also if its a new needle with the plastic end on it there is a little trick to get them to seat. With the needle in the seat you tap on it a couple times whcih get the plastic end to form to the seat and put it back togeather. I don't tell people about this often becasue if you tap to hard you can destory the plastic on the needle and then your in trouble.
Post a Followup
