Re: TA: Use it or Lose it... True?
Posted by IH in Waddy on August 09, 2005 at 10:34:09 from (12.154.100.33):
In Reply to: TA: Use it or Lose it... True? posted by Jim Allen on August 08, 2005 at 19:30:38:
I worked at a case IH dealer and the way we allways checked is put it in a higher gear full throttle load the brakes with the t/a in high side then pull back to low side real quick. If t/a is good it will snap right into low. If it hesitates and grabs you will soon be putting one in. If you dont want to spend the money leave it in high and take the handle off. The low side is the wet side it wont slip in high as this is the gear side. hope this helps out
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
