Re: 454 problems
Posted by RustyFarmall on August 18, 2005 at 14:32:39 from (199.120.81.204):
In Reply to: 454 problems posted by Galen on August 18, 2005 at 14:28:43:
Vacuum leak? Load jet not set rich enough? Getting plenty of fuel to the carb? Possible ignition troubles? How well did you clean the carb? I know, I'm asking more questions than you did.
Post a Followup
