Cub Hydralic Pump (rebuild)
Posted by GNB on August 23, 2005 at 18:49:31 from (205.188.117.73):
I have ordered a kit to rebuild the touch control pump on my 49 Cub. Just wanted to know if there are any pointers on doing this or odd wear to look for inside the pump, because I take it that the Kit has only the seals and o rings. All I have to go by is a exploded view of the pump. The seals must have went bad because I am getting lots of Hydralic Fluid in my oil and it is a new engine. Thanks in advance.
GNB
Post a Followup
