Re: Cub Hydralic Pump (rebuild)
Posted by Rudi on August 23, 2005 at 19:56:19 from (69.195.156.80):
In Reply to: Cub Hydralic Pump (rebuild) posted by GNB on August 23, 2005 at 18:49:31:
GNB:
The best help I can give you is to point you again to the Cub Manual Server at www.cleancomputes.com/Cub/index.html.
The instructions are there.... under Cub Maintenance Manuals and the GSS-1024 under the Blue Ribbon Service Manuals.
Post a Followup
