Re: SUPER C STARTER PROBLEM - NEED HELP.
Posted by DCTX on August 29, 2005 at 08:20:30 from (207.69.138.134):
In Reply to: SUPER C STARTER PROBLEM - NEED HELP. posted by farmallhal on August 29, 2005 at 07:49:52:
1-To remove the starter you do not do anything to the hydraulic unit. Remove the starter bolts and ease the starter out.
2-Your starter may be locked. Mine does this at random. I loosen the bolts, jiggle the starter until unlocked-making sure transmission is in neutral-turn on switch and try starter. If it works retighted bolts. I carry a wrench in my tool box for this. Some people put in 4th gear and rock rear wheels.
3-Your starter switch-on the starter-may need cleaning. Only done this once in 11 years.
4-Last but not least, your starter may need work done on it. If all else fails take it to a reputable starter/generator shop. They will will test it and repair as necessary. If the starter tests out okay usually there is no cost.
5-I am sure you will get plenty of good advice on this site-I have found it invaluable.
Post a Followup
