Re: H brake band adjustment question
Posted by P Backus on September 07, 2005 at 21:11:35 from (69.128.32.90):
In Reply to: H brake band adjustment question posted by Bob Frey on September 07, 2005 at 13:51:26:
This is a common problem on the band brakes. Like the other
guys are saying, it can be the cam plates on the shaft. But it can
also be that the aftermarket brake bands are just a little too
long. Do you still have your old ones? Lay them next to the new
ones and compare the length of the band itself. If you can find a
shop that still will reline brakes, they could set them up correctly
with the right thickness of lining.
On my own H, I was going to try cutting the band, remove
perhaps 3/16" and rewelding it with a wire feed welder. Just
don"t all jump on me for "tampering" with my brakes.
Paul
Post a Followup
