Re: Brakes Sticking
Posted by Ernest on September 09, 2005 at 10:53:02 from (205.173.169.253):
In Reply to: Re: Brakes Sticking posted by Illinois Boy on September 09, 2005 at 10:01:34:
Could be lots of things mentioned above. OR More like
balls and springs need cleaned inbetween the disc (the
caliper) OR what we found out on our 400 was the
brake shaft witch the disc slide on have grooves in
them dad took a smale file and filed them smooth and
no problems for about 3 years now!
Work perfect, we tried new balls-springs, oil-grease-dry
silicone lube(all at different times) new disc adjusted
them tight-loose. No luck for about 10-15 years. It does
get flustrating having to back up every time you use the
brakes.
Good luck! Let us know what you do to help!
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
