Re: Farmall 656 disl can't keep it running???
Posted by mike_r on October 06, 2005 at 19:44:26 from (69.216.107.241):
In Reply to: Farmall 656 disl can't keep it running??? posted by Country_24605 on October 06, 2005 at 18:55:30:
Are you 100% certain there isn't any blockage between your fuel tank and filter? I encountered a similar problem on a telescoping forklift where a bee had gotten in the fuel tank and clogged the line. Drained the tank, replaced the filters, fuel pump, injector pump, the works...all for a simple bee. It was a four cylinder and two of the four would spurt fuel. Might be something worth looking into.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
