Farmall 656 disl can't keep it running???
Posted by Country_24605 on October 06, 2005 at 18:55:30 from (69.139.105.41):
I have gotten a 656 farmall and about 2 weeks ago we was putting up hay when it started actin up and quit. ever since then it will run about 10 seconds or less like it ain't getting no fuel so i sent off the fuel pump to have it rebuilt or to see if there was anything wrong with it well i got it back about 3 days ago and changed fuel filters and everything got everything back in time and got all the air out of everything but same ol story and before i put the new pump on i did drain the tank and put different fuel in it incase there was something in it...... so i worked and worked for about 2days on it and still puzzled oh and my #1.#5.#6. injectors work they will shoot fuel.. #2 injector might get 4 drops from it and #3&4 nothing comes out and the lines are not stopped up? The pump was supposed to have been rebuilt but now i am woundering????? Any help would be greatly helpful.. anything else it can be or might try?
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
