Re: Farmall 656 disl can't keep it running???
Posted by Allan in NE on October 07, 2005 at 04:08:53 from (148.78.243.25):
In Reply to: Farmall 656 disl can't keep it running??? posted by Country_24605 on October 06, 2005 at 18:55:30:
How about that fuel feed line between the fuel filter and the pump?
You're starving for fuel somewhere.
Allan
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
