Re: No Fire
Posted by Geoff NY on October 08, 2005 at 16:05:56 from (24.185.231.211):
In Reply to: No Fire posted by Jeffnofirefarmall on October 08, 2005 at 14:57:03:
The most usual problem is a wire shorting out. Most of these old gals have dry rot in the wires or the groumets where the wire passes through the mag housing. After you are certain that the wires are good check for dirt and rust in the mag. Good luck.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
