Re: Novice needs help with a Farmall H.
Posted by Jay (ND) on October 12, 2005 at 09:56:30 from (66.231.126.200):
In Reply to: Novice needs help with a Farmall H. posted by Brad from PA on October 12, 2005 at 09:53:13:
$5 says you flooded it. They flood easily. On both my M and my new H, I open the throttle about 1/4 to 1/3, hit the starter and pull open the choke for maybe 2 seconds. More than that and they will flood.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
