Posted by Owen Aaland on April 07, 2009 at 21:39:07 from (65.165.246.54):
In Reply to: IH books posted by Bob S. on April 07, 2009 at 21:11:39:
There is an aluminum spacer that goes across the main bearing cap in the back of the block. The long bolts go through the ends of this block. They need to be longer because they have to pass through the spacer before they can thread into the block. The threaded hole in the center of the spacer should have a stud in it instead of using a bolt. It is very easy to over tighten the center bolt and strip the threads out of the aluminum.
When checking leaks in the front corners of the oil pan be sure to check for a crack in the pan.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
