Re: super M disk brakes
Posted by Janicholson on October 26, 2005 at 08:49:41 from (199.17.6.175):
In Reply to: Re: super M disk brakes posted by david/chainsaw on October 26, 2005 at 08:14:27:
As described, it is not rocket science in there. Clean with Brake-Clean, or other spray solvent. don't breath the dust, it is asbestos laden. lube the three balls in the wedge plates with a -thin- coat of moly anti sieze or silicon grease, not oil.
Use Tri-flow spray on the linkage pivot points, but don't get it on any surfaces. Sanding the friction surfaces will clean them up. sand around and around, not across the surfaces, and evenly.
The little rubber boots on the front keep water out to a degree, but use is the best preservative.
If the friction plates are even half worn compared to new, the brakes may not have enough adjustment to work well. Expect two years or so out of the cleaning.
Been in there a lot.
JimN
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
