Re: diesel fuel treatment
Posted by El Toro on October 30, 2005 at 15:42:26 from (64.12.117.13):
In Reply to: Re: diesel fuel treatment posted by Hugh MacKay on October 30, 2005 at 15:06:23:
Hi Hugh, The military uses a diesel fuel known as DFA. We had vehicles at-65 degrees we never had a gel problem. The vehicles with coolant heaters usually would start. The best were the Soviets with 10 minutes of preheat would start like summer time. We made 3 starts using the
same batteries. We had a thermocouple in the engine oil pan and we would soak until the temp
reached -65. I don't think much fighting would be going on at that temp. Hal
Post a Followup
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
