Re: 49 Farmall H RefusesTo Start
Posted by El Toro on November 01, 2005 at 18:56:45 from (152.163.101.13):
In Reply to: Re: 49 Farmall H RefusesTo Start posted by Flatland Farmall on November 01, 2005 at 18:50:46:
Should be 12 volts at your starter & switch. The
ballast resistor will drop it to 6 volts to the
ignition. Hal
Post a Followup
