Re: Oops. Now I did it. M question
Posted by Haas on November 07, 2005 at 19:24:15 from (12.65.72.5):
In Reply to: Oops. Now I did it. M question posted by e-manhunt on November 07, 2005 at 18:09:55:
As Jani said, you have likely tried to remove the hydraulic (Lift All) unit to get at the lost bolt. That unit is very heavy and the drive connection to the transmission as well as the pipe connections and the control connection on the side has to be removed to get it out. It is held in by four 3/8 inch bolts. If you decide to remove it, make sure you have help and do not drop it on any of your body parts, as it weighs more than 100 lbs. I also, do not agree that the bolt will do no harm. I don't think there is room between the ring gear and the housing to clear a bolt of the size (1/2 inch??) that holds on the starter. It's gonna get wedged between and something will be damaged. I think the magnet suggestion is a good start. Beyond that, I don't see much option except to drop the lift all unit. I'll take a look at mine tomorrow and see if there is an inspection hole I've forgotten about.
Post a Followup
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
