Re: IH 686 Tractor- 70's
Posted by 7D Ranch on November 09, 2005 at 17:59:22 from (66.82.9.80):
In Reply to: Re: IH 686 Tractor- 70's posted by JB2 on November 09, 2005 at 17:39:44:
Thanks JB2,
I will look for it tommarow. Is it something that is adjustable? If so I would imagine screwing in would increase spring tension and increase hydraulic pressure. Or does it appear to be a set relief valve, in that case I would need a new spring and ball I assume or maybe there is some contamiation under the ball.
One thing I forgot to add is that the loader will not lift the front end of the tractor off the ground when given down pressure, so I assumed it wasn't running out of fluid and the pistons are not extended, but with the pistons extended going up, it may need to be over full with fluid. Any kind of real loader should lift the front of the tractor off the ground right?
Thanks Again,
7D
Post a Followup
