Re: 434 starting last time I hope
Posted by El Toro on November 13, 2005 at 07:20:07 from (64.12.117.13):
In Reply to: 434 starting last time I hope posted by Al Sproule on November 13, 2005 at 06:42:33:
Are you sure that wire isn't hooked to your switch? One of those wires on the solenoid should be hot (have voltage) that feeds voltage to your switch. There should be another wire off your switch that's connected to the s terminal on your solenoid if this a key start.
This wire would only be hot when cranking your engine. Check that wire for voltage by just probing through the insulation covering that you have trouble tracing. Hal
Post a Followup
