generator question
Posted by jeg on November 13, 2005 at 16:24:58 from (207.200.116.203):
this is on another kind of tractor but I figure the principles are the same. The "idiot light" goes off indicating a charge is being put out. The reading at the battery is 12.5 volts when the tractor is running. When I disconnect the battery when the tractor is running it dies. Should it keep running ( ie using the charge from the generator)?? I thinking about putting an ammeter on.
thanks
Post a Followup
